It is currently Sun Aug 24, 2025 11:10 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Fri Aug 09, 2013 2:20 pm
PostPosted: Fri Aug 09, 2013 2:39 pm
I originally made my deck adjustable using 1/2" threaded rod with a threaded knob below and above the upper support. Works like a charm, but it's slow. I just have it adjusted for closing the soundbox now and throw a riser block below the radius dish now like Colin.
PostPosted: Fri Aug 09, 2013 3:03 pm
My point wasn't that it was easier, cheaper, etc., just that using a riser block under the work, rather than adjusting the height of the top of the deck, makes more sense to me.
It's quick to adjust, if say I'm making a uke, then just add an extra piece of ply under the dish. I'm a great fan of using the lowest tech that will get the job done. At my day job, I will use the University's Cray for a lot of my computation work, but sometimes it's overkill, when a pencil and the back of an envelope will get the job done. I don't like to over-think what should be a simple process.
PostPosted: Fri Aug 09, 2013 6:14 pm
Thanks, Miguel, I've ordered the things for £11.20. I'll let everyone know if they work or not! :)
Worst case, I've wasted a few pints down the pub.
And thanks, Colin, I may well have to resort to that but this way seems to make sense to me. Horses for courses, I guess. (Beautiful soundhole in your profile pic, btw! :))
PostPosted: Sat Aug 10, 2013 8:54 am
Jim Kirby wrote:
Kathy Matsushita wrote:
Nick Royle wrote:
Are they Pony Clamps? Maybe I've gone blind but I can't find that page on her site.
I've seen people mention them but the only ones I have seen on sale here are relatively expensive.
Any Brits tried this?
I had found some cheaper Pony-type clamps, and used some of those, along with some older Pony clamps I had on hand. It is a little bit expensive, but worth it in the long run, because of how easy it makes it to change the height of your deck....
http://home.comcast.net/%7Ekathymatsush ... ueback.jpg
Kathy,
What are the inserts in the top and bottom plate that your pipe ends are threaded into?
Jim: i think I basically did what Stew-Mac does on theirs (
http://www.stewmac.com/freeinfo/Jigs/i-4733.html). The pipe ends just butt up against the big washers. (The thing that's actually holding the deck together is threaded rods, washers, and nuts.). I've seen someone else who, instead of that, just screws pipe flanges to the corners of the boards (no threaded rods).
Kathy Matsushita
San Jose, CA USA
http://theamateurluthier.com
Facebook: https://www.facebook.com/kathy.matsushita
